mech oil pres guage
Old 01-10-2009 | 05:24 PM
cbschmidt's Avatar
mech oil pres guage
i mounted a mechanical gauge for oil press inside the cab and ran line to the plug on top of filter housing, it seems to read the same as the dash gauge after warm up. is there a more accurate location to take pressure from or is the filter housing the same as the rest of the block. thanks, great site
Old 01-10-2009 | 05:29 PM
comptz's Avatar
That is where i plummed my gauge in at
Old 01-11-2009 | 11:45 AM
infidel's Avatar
It's more accurate than the stock gauge.
My understanding is the stock gauge has a 5 second delay in the electronics, that's why you see different at warm up.
Old 01-11-2009 | 01:52 PM
cbschmidt's Avatar
seemingly way more accurate, in the morning the mech gauge goes up to 80+pounds while dash sets at 40, they both drop to about 22 @ idle after warming up but the dash gauge is misleading.
Old 01-11-2009 | 07:37 PM
flippy1974's Avatar
i have mine on the block on the drivers side . i put a tee in there and left the factory and mech at the same time .
Old 01-11-2009 | 11:46 PM
1stGen545's Avatar
this is the stock location. just remember that oil goes from the pump to the filter housing then the rest of the engine. then as it goes threw the system pressure drops because every thing it oils is like a controlled leak. so it should show lower and slower on start up on the factory gauge because you have to pressurise the hole system before you see pressure where the factory gauge is. I would want to see were the lowest pressure is to know it was good (no worn bearings) then at the filter. 80psi at the filter is no good if you only have 10psi at the rear main.
roadrage1
09-03-2011 09:00 PM
wanago
02-09-2011 07:38 PM
231jasons
22
08-24-2007 02:41 PM
jon05ctd
08-27-2006 05:14 PM
Barry Smith
11-14-2004 10:56 PM
