max rpms out of a 12 valve?
what is the maximum rpms you can get out of a 12 valve with a p pump. someone told me like 6000 and i said that seemed really high. but if its built is it possible?
At 6000 rpm piston speed will be nearly 5000 fpm. I would expect a failure from a stock crank and rod with in 10 seconds.
The piston is far to heavy to run that kind of rpm on stock components. With a light piston, strong rods and treated crank....it might survive for short term use in a race only vehicle.
You might also run into other problems at that rpm....cam harmonics, p-pump cant spin that fast with out coming apart??, etc.
jschintgen
12-31-2009 11:17 PM
gncc 621
02-09-2009 09:48 AM
12valve
03-11-2008 10:57 AM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
