Manual shutdown?
If I'm misunderstanding what solenoid, please excuse my mistake.
If you mean the fuel shutoff solenoid that opens fuel flow when the starter cranks the engine, and shuts off fuel flow when you turn off the key, then I don't know if anyone offers a kit - but you can use a push-pull cable from the auto parts or lawnmower shop. Someone on this forum wrote it up and that's what I did when the linkage on my solenoid died. The solenoid was still good electrically, but the linkage to the arm on the injector pump broke, and it seems not to be available as parts, only with the solenoid assembly.
I hope this helps. If you do a "search" for "fuel shutoff solenoid" you will find the instructions someone posted. It is an easy fix.
Regards,
Andrew
Regards,
Andrew
1ATony
1A Auto
0
07-26-2013 09:30 AM
Crossy's son
03-20-2008 04:35 PM
Dodgezilla
14
11-11-2006 10:05 AM
ezdemon72
14
07-29-2005 10:05 AM
