Major Trans problem….
I have a major problem with my truck. It started last night I came to a coast and the go back on the throttle and at about 15 mph it felt like the TC locked up and lugged the engine. I shifted to neutral and it quit then I went back to drive and it had no problem. And I drove on home. Today on my way to work I came to a stop after getting lunch and it did it again but this time after the going to neutral and back to drive it did it again about 6 more times till I got to work the last time it killed the engine. So I stuck it into 4 LO and let it idle to a spot. About 30 minuets later I got back in it and went for a spin with no trouble. Any ideas? The trans is completely stock at least to the best of my knowledge. I was saving for a built trans may be getting it a little sooner tan I thought
Chris
Chris
It had no trouble going to work today I called Dave Goerend and he said to remove the relay and see if that helps well i have had no problems today. However tonight on the way home i stuck the relay back in just to see what happened. It ran fine so i pulled over and pulled it out when i did the relay was warm not hot but not cold like the others in there. I have also noticed that with the relay out i cant go into 1st gear manually and it seems like my converter is slipping more than ever but i think that's because its trying to start in 2nd when im in first or second or in third if im in drive. any thoughts on what else i might try to me it seems like a classic symptom of having a problem but it not reveling itself when you need it to.
Chris
Chris
The Boss Hog
01-24-2003 08:44 PM
