Low shift points
Old 01-18-2005 | 08:54 PM
Charlie Hardin's Avatar
Low shift points
I installed a transgo kit in my auto and now the 1-2 and 2-3 shift points are at very slow speeds. Moving the throttle cable seems to have very little effect. Any ideas on raising the shift points?
Old 01-19-2005 | 04:43 PM
MDMIKE's Avatar
Bump. After the install of my BD valve body the shifting was definately improved, but after the GSK I could stand a few more RPMs between 1st and 2nd and 2nd to 3rd. TIA
MIke
Old 01-19-2005 | 10:39 PM
tmiller24's Avatar
If the TV cable is properly adjusted, then the best way to adjust shift points, is spring changes, inside the valvebody.
Old 01-19-2005 | 10:43 PM
Thanks. Looks like I'll have to recheck my transgo instructions. Good thing I installed a drain plug before I replaced the pan. Saves a lot of mess. Charlie.
Old 01-23-2005 | 01:42 PM
got...DIESEL?'s Avatar
if you got a transgo kit, and installed the heaviest spring in the TV valve assy, you might swap it out for the next spring down. Some have had luck putting a few turns on the PR screw to get some more line pressure, which will delay things a tad. Others yet, have put a bracket on the pan rail that limits the return rate of the TV lever. Makes the trans think you're putting more coal in the bucket than you are, and shifts later as a consequence. As I don't subscribe to the potions and lotions theories, I would make adjustments to the VB and keep everything running as intended without bandaids on bullet holes.
Feel fortunate, as most 12v owners CAN'T GET the darn things to shift under full throttle!! They would feel fortunate to have your problem
Playing with TV springs and/or pressure adjustments should get you going. Incidentally, throw the adjustment procedures out the window in the manuals. cable stretch and other factors may influence the end cable setting. Have a buddy hold the pedal to the wood and crawl under and grab the TV lever on the trans. You want it to be just a 1/16" or so from full rear position when the throttle is wide open.
Chris
Old 01-23-2005 | 04:08 PM
tmiller24's Avatar
got diesel?, has it right, mine won't shift at full throttle but I can live with it.
Old 01-24-2005 | 07:29 PM
jimk's Avatar
wide open up shifts
My 95 is has 103k miles on it. It has a bandaid brace on the throttle lever, but It will shift under wide open throttle. I had thought I may have to replace the transmission some day IF it fails. good luck Jim
mkrenn
01-24-2005 08:12 AM
Dodgezilla
05-30-2004 03:46 AM
ATVConnection
03-21-2004 09:15 AM
jlbota
03-15-2004 10:56 PM
cad14man
10-22-2003 05:44 PM
Quick Reply: Low shift points
