looking to get best mileage
i have a 1998 12v 1 ton that i am using to move laods 3000 miles 12000lbs-20000lbs , truck is completely stock , i am going to put a cold air , 4 inch exhaust , bump the timing to 15-16 , going to put a water meth kit on it as well . what else should i be doing on this truck for better mpg
YOU DONT MENTION IF YOUR TRUCK IS 4 WHEEL DRIVE! IF IT IS I WOULD DO A FRONT HUB CONVERSION FOR BETTER FUEL MILEAGE http://spyntec.com/dealers/
I think using syn gear lube will get you pretty close, without the big expense. Its funny, but when I had my PSD and frequentd those forums, they all wanted to know how to convert their manual hubs to one like we have on our dodges. Grass is always greener...
Jimmy
Jimmy
Add propane. It acts somewhat as a catalyst, helping the diesel burn better. When set up correctly, it will add more fuel mileage than cost. Oh, and more powertoo lol!
I wouldn't spend the money on an intake. The stock airbox with a good filter is said to be good to 500hp and you can make a hole in the box and the firewall and connect them with a hose for a true cold air intake for under $50 if you already have the holesaw. I have a big cone and heat shield on mine and I want to go back to a stock box.
John
John
Some say running a 190* thermostat works wonders for fuel mileage. I put a 190* stat in my truck but didn't really notice anything mileage wise.... but then again I put it in just as it got colder and did not see a mileage drop, so maybe it did help....
If you want to try the stat thing, 45479 is the STANT part number I used. It's actually for a 440 BB but works perfectly. Drilled a 5/64" hole in it to prevent temp surging. Been working real well all winter for me.
Mine cost $2 since I had the holesaw.
Cold air intakes do lower mpgs by lowering egts which in turn allow you to stay in a higher gear while towing or on hills.
I doubt a cold air intake would help out a stock truck in towing mpg's. Stock plate doesn't really give enough fuel to make EGT's an issue does it? My EGT's were never a problem until I ground my plate to a 100.
The "Filter Minder" on my stock airbox with clean paper filter was showing all red after a short/spirited trip with just a 100 plate and 3k spring. I have since replaced with a BHAF.
John
Makes perfect sense.
