list of upgrades 12v
Old 04-24-2015 | 11:50 AM
eloera5's Avatar
Hi I am new to diesel trucks and I would like to know what upgrades I can do to my engine to start off.
Old 04-24-2015 | 02:46 PM
R Walter's Avatar
Suggest you provide more information about your truck. Auto vs manual? Year? And so on.
In general, first a set of gauges. Again, if auto, you'll need an auto trans temp gauge. Certainly a boost gauge and a pyrometer whether auto or not.
Make sure you have the KDP fixed. A fuel plate and governor spring kit would be next on my list. If a stock auto, plan on it being a problem area as you increase the fueling. Conversely, if a manual, plan on a better clutch at some point. Also, you can add more air with a better air filtration system and a bigger exhaust will also help your diesel to perform better by keeping exhaust gas temps lower to not destroy the turbo.
This is basically what I've done to my two 1996s, one an auto and the other a manual. They're not extreme performers, but they do run very strong without two much additional stress and strain on the trucks.
Old 04-24-2015 | 02:59 PM
eloera5's Avatar
Well it's a 1995 cummins 12v auto. I know my transmission will be a problem I just want it to be stronger and faster. Thanks for the reply though I will sure use that info.
CruisingRam
04-16-2006 09:14 PM
AKdodge55
10-13-2005 12:17 PM
012500
11-29-2004 10:47 AM
GreyBoy
10-24-2003 04:04 PM
Quick Reply: list of upgrades 12v
