Light Throttle Stumble
I've developed a stumble or miss when I'm on the throttle lightly. It will clear up if I step on it. It is really noticeable with the TC locked around 1800 rpm and somewhat noticeable at lower speeds (TC unlocked) and lower RPM's. So far I've replaced my rubber fuel lines, fuel filter, and pre-heater gasket thinking the I possibly had a little air being drawn into the fuel. (I can see a few bubbles right when I crack the injector lines but it will clear up in a few seconds). I also re-installed my 180 injectors and it actually seemed to make the stumble at lower RPM's more noticeable. Boost, EGT's, oil & coolant level are all good. About 2 months ago I did have my timing bumped from stock to 15.5°. I'm thinking (hopeing) that it may have slipped. The TC seems to hold good in lockup so I don't think it's starting to separate. Any ideas?? HELP...
TIA
Paul
TIA
Paul
pwrtripls1
02-09-2012 08:46 PM
Sandaholic
07-18-2008 06:38 PM
dodgediesel
43
01-20-2008 01:05 PM
d-hlaw
15
07-22-2007 10:03 PM
ciamcoop
07-22-2007 09:39 PM
