lift pumps
Old 12-28-2007 | 09:33 AM
dv_shane's Avatar
lift pumps
i am running 100% bio-diesel in my truck for the past 6 mos. the only trouble i have is i have went through 3 pumps in 6 mos. i am using the old style pumpwith a diafram in it. does anyone else have this happen to. for once i am glad i bought something at autozone cuz they keep giving me new ones. also if i change to a piston pump will b100 harm it to or not? thanks
Old 12-28-2007 | 09:35 AM
Shovelhead's Avatar
Administrator / Scooter Bum
What year/make/model?
Old 12-28-2007 | 08:25 PM
dv_shane's Avatar
92 d350 5.9 turbo/cummins
Old 12-28-2007 | 08:27 PM
Shovelhead's Avatar
Moving this to 12 valve Engine & Drivetrain for better exposure.
Old 12-28-2007 | 10:58 PM
NMCTD's Avatar
I think if you switch to the piston pump for a 94-98 it will cure your problem, I don't think they are affected by bio. The bio is probably tearing up the diafram in the older pump.
Also for knowledge cummiins has a new part number for the piston pump that is much cheaper, I just bought one from my local cummins dealer. Here is the numbers and prices he gave me.
#4944710 $81.83 if this isn't avail. it superceeds to #4988747 $84.24
and gasket is #3939258 $1.86
Hope this helps....Josh
Old 12-29-2007 | 05:30 PM
dv_shane's Avatar
thanks josh for the part numbers i knew there was a piston type pump that
would work but calling cummins to get any info is a loss.
dave
Old 12-29-2007 | 09:59 PM
NMCTD's Avatar
Your welcome
I've never done this swap before (never owned a 1st gen) so I don't know if anything needs to be changed on your truck to use this pump, but it shouldn't be much if there is, 1st gen guys should be able to tell you though.
good luck....Josh
Old 12-30-2007 | 03:28 PM
Daver43's Avatar
Look here on the pump upgrade. I have this one printed out in my shop. Hope it was what you are looking for. Dave
https://www.dieseltruckresource.com/...ad.php?t=93722
Old 12-31-2007 | 07:10 PM
dv_shane's Avatar
thanks guys i read the how to and all i am going to get the parts after new years and do this i just had to get a pump from autozone to keep it running
thanks to the warranty on the pump this is number 3 i wonder how many i can get before they figure whats up? bio dont last long in these old style pumps. thanks dave
Ilikebikes
12-11-2006 10:13 PM
Duelin
46
03-12-2003 08:56 PM
dodgeboy59td
02-12-2003 11:08 AM
dieselcrazy
02-07-2003 07:00 PM
drecu
52
11-25-2002 04:11 PM
Quick Reply: lift pumps
