Lift pump replacement
Old 10-01-2006 | 07:55 AM
RZinKY's Avatar
Question Lift pump replacement
I pulled my lift pump and removed the brass fitting the fuel line to fuel heater attches to. What type of thread sealer can be used. would teflon tape work.
Thanks Jeff
Old 10-01-2006 | 09:23 AM
Racer9's Avatar
I believe you don't want to use any tape on the threads, as it can work it's into the system and wreak havoc, plugging injectors and things. You shouldn't need it with brass fittings anyway.
Old 10-01-2006 | 09:55 AM
RZinKY's Avatar
The brass fitting I removed had some type of sealer. The fitting is a standard pipe thread wouldn't it need something
Old 10-01-2006 | 10:46 AM
TxDiesel007's Avatar
I used some permatex
dont know if its right or if its wrong, but it worked well for me..
More info if u need it..
https://www.dieseltruckresource.com/...mp+replacement
Rick
Old 10-01-2006 | 11:24 AM
infidel's Avatar
Permatex #2 is what I use.
Old 10-01-2006 | 07:32 PM
boostedte37's Avatar
what he said
Old 10-01-2006 | 09:38 PM
RZinKY's Avatar
I used some permatex 2. I don't know if it was the lift pump or the very old fuel filter, but it runs alot better. really cleaned up the bottom end, and starts when you touch the key.
Thanks for your info
Jeff
Old 10-03-2006 | 08:16 PM
GearHd6's Avatar
Jeff
Really? Thats probably my next repair. Mine will sometimes start up and idle a little slow for a few seconds and then pick right up. Its got 185K on it so it could be time.
Txwelder
12-18-2023 02:35 PM
mstep3
23
07-27-2010 02:22 PM
Txwelder
05-19-2005 06:10 PM
w4xtc
03-14-2004 09:14 AM
AlpineRAM
01-30-2003 03:24 AM
Quick Reply: Lift pump replacement
