lift pump pressure high?
Old 07-04-2003 | 09:25 AM
winner172's Avatar
replaced my overflow valve and my pressure now is
22psi @ idle and 35psi @ 2500. it seems to max out at 35. is this too much? the book calls for 25-30 psi at 2500. i noticed the hole in the bottom of the overflow valve was smaller than the one i replaced.
Old 07-07-2003 | 05:48 AM
Jim Fulmer's Avatar
Re:lift pump pressure high?
Overflow valves are rebuildable as long as the seat is good, you can change out the spring and ball or shim the spring for higher pressure. I run mine at 33 psi, if you worried about it try the spring from the old overflow valve.<br><br>Jim
schamran
10-29-2013 07:06 PM
mullishacrew
03-18-2012 12:41 PM
The_Head
10-14-2011 10:27 PM
The_Head
01-28-2010 10:36 PM
Quick Reply: lift pump pressure high?
