Lift pump P/N
Old 02-22-2005 | 01:05 PM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Lift pump P/N
There was a thread a while back that had the CASE P/N For carter lift pumps for our trucks. Can anyone find it or point me in the right direction. Anyone know the P/n off the top of there head? I have to have my mother get me one down in texas. She needs the P/N. Thanks in advance, Zack
Old 02-22-2005 | 06:50 PM
infidel's Avatar
You can get the same lift pump at any Napa for about $100, just tell them your truck's info. The cummins number is 3936316
Old 02-23-2005 | 01:31 PM
zack_76401's Avatar
I have a 12 V not a 24 V what is the moderator moving this to 24V for......
Old 02-23-2005 | 01:32 PM
zack_76401's Avatar
The pump at napa is for 12V correct?
Old 02-23-2005 | 02:14 PM
infidel's Avatar
Yes
Old 02-23-2005 | 03:54 PM
zack_76401's Avatar
I called Napa all they have listed is a injection pump......they asked if i had a napa PN. They know nothing about diesels at this napa....wish i was back home....
Does anyone have the napa P/N or CASE P/N for a 12 V lift pump?
Old 02-23-2005 | 07:03 PM
infidel's Avatar
It sucks when the counter guys get lazy. Just going to www.napaomline.com gave me this number in ten seconds M73104
List price is $154 but depending on what kind of account you have at Napa the discount is up to 33%. Don't think anyone has to pay list.
Old 02-24-2005 | 01:01 PM
zack_76401's Avatar
Thanks I found the case part number last night.......with alot of digging.....it is the exact same pump but way cheaper than i can find anywhere.even with military discount. Thanks for chiming in and helping Infidel. I appreciate it.
Zack
Old 02-24-2005 | 01:28 PM
infidel's Avatar
So what's the p/n Zack?
Old 02-25-2005 | 12:32 AM
mt72916's Avatar
can't find older post but i did copy case p/n to a file
lift pump Case P/N J936317
gasket Case P/N J939258 (two required)
carter p/n M73104
mel
Old 02-25-2005 | 04:19 AM
kd460's Avatar
Don't have a part number, but I have read that international parts dealers have the lift pump as well for a really good price. It seems our engine is used in all kinds of applications. Kevin
Old 02-25-2005 | 07:48 AM
Rhino's Avatar
Careful, the Case pump may not work on your truck. There was a thread on the TDR where one member had problems with making the case LP work. There is one fitting that needs to be swapped between the case pump and the original pump and apparently with some original LP's this fitting cannot be swapped between the two. tthere was some pictures posted to determine if it can be swapped or not.
As far as NAPA goes. I paid $128 for my LP from them. I can dig up the PN if you would like it.
Old 02-25-2005 | 08:17 AM
zack_76401's Avatar
The case pn i got is the same as above.......the guy that origanilly posted this number is bramage. He says on the thread, " This is the exact same Carter pump but in a case box. You will need to swap one fitting from your old pump to the new pump but it is self explanatory when you hold the pumps side by side"
His sig doesnt list what year truck he used it on. I have a 98 Does anyone know if it works with this year. Were the carter 12v pumps all the same for 94-98?
Napa wants over 160 for it.
Old 02-25-2005 | 02:23 PM
Rhino's Avatar
No.
Old 02-25-2005 | 02:49 PM
zack_76401's Avatar
Welll DA** Now I'm stumped.......
Anyone out there tried the CAse Pump and what year truck do you have?
Quick Reply: Lift pump P/N
