lift pump
Old 08-24-2003 | 01:18 AM
wagontrain131's Avatar
lift pump
How can you tell if your lift pump is going bad or has gone bad? Is there any change in performance,sounds,etc...
Old 08-24-2003 | 05:15 PM
RCW's Avatar
RCW
Re:lift pump
When most lift pumps go bad you do not even know it. Most failures are seal related with fuel leaking out the primer plunger or down the pushrod and into the oil pan. Some people notice a pool of froth under the blow by tube from an internal leak, or see fuel on their finger when pushing the primer, or their fuel mileage starts dropping dramatically.
Other lift pump failures are most often noticed when they stop pumping, and that is usually a fairly quick failure. When that happens the fuel will either be foamy, or no pressure or very low volume. Most often the rig will quit running or be very hard to start and then die frequently in hot weather.
Slow loss of power is generally plugged filters, air leak in the turbo plumbing, or an air leak in one of the fuel filter housings or the flex lines, or the injection pump overflow valve giving up the ghost.
Slow loss of power and a gradual tendency for the truck to start to run high EGT's is generally the timing sliding down below 9 degrees.
Old 08-27-2003 | 11:42 PM
Re:lift pump
Thanks RCW thats all the info i need. Sounds like I have a timeing and not a lift pump problem, but now i know what to look for. Thanks alot
Txwelder
12-18-2023 02:35 PM
Txwelder
05-19-2005 06:10 PM
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: lift pump
