lift pump
Old 12-19-2006 | 10:28 AM
mainer's Avatar
lift pump
i've been getting a ticking noise from down by the lift pump for quite a while now, its off and on, seems to do it randomly and only at idle to 1100rpms or so.
the truck has ran fine until the last 10 days or so.
randomly at wide open throttle (wot) it will die/ cut out for a second like feels like i've run out of fuel then come right back and be fine.
then the last few mornings when i start it (been fairly cold low 30's high 20's) it ticks really bad for 20 seconds or so.
then today i started it up and it ticked, went to class 10 mile drive, then 2 hrs later start it up and it ticks... then i'm in the truck idling talking on the phone and it cuts out drops 75rpms a couple of times but then returns to normal idle after each time.
is this my lift pump going?
i pulled the overflow valve out a couple weeks ago and measured the spring and it was within spec.
where is the best place to get the lift pump?
i have a freightliner dealer about 3 miles up the road, but where is going to be the cheapest, i'm on a budget.
how long can i expect it to take me to change the pump... i've done a few on 1st gens but never had to work on the 2nd gen.
the truck is a 1998 12v with 111,000 miles, i assume its the original lift pump.
Old 12-19-2006 | 12:54 PM
cheapskate's Avatar
i found one at napa for somewhere around 120-150? something like that. check their on-line cataloge
Old 12-19-2006 | 04:37 PM
waldersha's Avatar
Usually around $150 from the parts houses. I did find a site that lists them for $65 called savesave.com, but I have no experience with them. Plan on a couple of hours to change it out. Kinda hard to reach everything and line it all back up again.
Old 12-19-2006 | 06:58 PM
infidel's Avatar
The same fellow who sells cheap overflow valves can get you one for around $100
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
Old 12-20-2006 | 03:08 PM
mainer's Avatar
just ordered one, hopefully it fixes the problem.
precision diesel was great to deal with.
Old 12-20-2006 | 06:26 PM
infidel's Avatar
Just don't mention football to Marty if you want to get off the phone in a reasonable amount of time...
Old 12-20-2006 | 09:12 PM
mainer's Avatar
haha, i'll remember that, didnt actually talk to marty as he had left for the day, talked to a woman, wife maybe? i'm not sure, cant remember her name, but excellent service, even went and made sure they were actually in stock.
Txwelder
12-18-2023 02:35 PM
Txwelder
05-19-2005 06:10 PM
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: lift pump
