less power and torqe when warmed up
95 dodge 4x4 cummins with 230 plate in it ,.
and big airfilter/
have owned this truck like 4 months and it seems to me that it has less power when its warm. is that all in my head or is there somthing to cause that,
and big airfilter/
Have you adjusted the valves yet? If they're too tight, you could be losing some compression as the engine warms up and the components expand. Worst case is a valve could kiss a piston, so it's best to check them. .010 I .020 E
g
g
If the shutdown solenoid is full of crud or the shaft rusted it can drop down a little once it gets hot.
Solution is easy, remove and clean, don't lose any parts, replace the boot if it's rotted out.
Also check that your throttle cable is in good shape and pulling all the way back to the stop when the pedal is floored.
jmccart
07-17-2008 10:05 AM
jesse_jamz
42
01-28-2008 08:19 AM
out4elk
08-12-2007 01:24 PM
memphisaudio
10-11-2003 01:00 AM
