LED Lockup Switch ?'s
Old 04-18-2008 | 06:19 PM
rollerink's Avatar
I already have a lockup switch installed on my '96. I bought an LED toggle switch to help me remember when the lockup switch is on or off. The question I have is where or how to I get power to the switch. The instructions say it can either come from the battery or fuse panel. I would rather not run a wire to the battery just to power the toggle switch. How do you get power to the switch from the fuse panel in the cab???
Old 04-18-2008 | 09:40 PM
xzaq103's Avatar
Do you have gauges? You can just strip the end of the wire and stick it in a fuse spot in the fuse box on the side of the dash. The cig lighter should work.
Old 04-19-2008 | 01:03 AM
TB1's Avatar
TB1
I used a 12 volt relay and an switch with a led light in it works great. Here is a link to the wiring diagram I posted on another site. this way the light will activate when the switch is on.
http://www.thedieselgarage.com/forum...9&d=1204352931
wiring.pdf
Old 04-19-2008 | 09:10 AM
blackimpala's Avatar
If you check at any auto parts store they have " fuse taps" you can install them with a fuse in the cab and tap a line to what ever you want.
Old 04-19-2008 | 09:20 AM
TB1's Avatar
TB1
The light will not work by just applying 12 volts to the switch I tried to do just that. I talked to my buddy who is an electrician and he told me to use a relay to wire it up or the light in the switch would not work. The above post has the diagram I made up when we did mine and it works. The biggest expense with be the $5 relay.
Old 04-19-2008 | 10:44 AM
infidel's Avatar
You can skip the relay by using a double pole single throw switch (DPST)
Use one set of switch contacts to trigger lockup and the other set for the led.
Old 04-19-2008 | 11:17 AM
TB1's Avatar
TB1
That's true But I already had the switch as well.
Old 04-20-2008 | 06:39 AM
WVAussie's Avatar
How many amps are being grounded through the switch during lockup?
Old 04-20-2008 | 01:06 PM
Yellow Yota's Avatar
Very good point. Much easier than doing both a relay and a switch.
Yesterday 09:17 AM
I'm curious about his as well.
Also, what exactly is the purpose of the resistor? I already have them, and intend to run one, but I'm curious why.
Old 04-23-2008 | 07:44 AM
WVAussie's Avatar
The resistor I believe is to stop the computer from going into limp mode. Im not sure that it works 100 percent of the time as I have had the truck go into limp mode with the resistor. Nobody knows how many amps are being grounded?
Angry Johnny
08-23-2016 05:01 PM
cowboykilla235
02-17-2013 03:02 PM
93dieselZak
06-16-2011 06:10 PM
JQmile
09-15-2010 10:43 PM
Cowboy_Customs
05-06-2008 09:39 AM
Quick Reply: LED Lockup Switch ?'s
