Leaking Vacuum pump?
Old 03-05-2003 | 04:42 PM
97Dually's Avatar
I took my rig to a dealer this morning and he told me that my leak was fluid from the vacuum pump. He quoted me 800 or so for a new pump and 3.5 hours of labor. Why do I need a new pump if the seals are bad? Help guys, $1300 seems scarey!!<br><br>TJ ???
Old 03-05-2003 | 05:06 PM
Monty's Avatar
Re:Leaking Vacuum pump?
Where you leaking oil or ps fluid? You can buy the oil seal and o ring for the vacumn pump. Do a search for &quot;vacumn pump leak&quot;.
Old 03-05-2003 | 06:13 PM
97Dually's Avatar
I'm leaking oil.<br><br> searched and found that There is a seal I can replace, rather than replace the entire pump. I just wonder why the only dealer option is to replace the pump too.<br><br>TJ
Old 03-05-2003 | 07:17 PM
D4Fritz's Avatar
The reason why the dealer did not suggest that is because they only know how to replace entire units.<br>
Old 03-05-2003 | 09:54 PM
EShaw's Avatar
Where ca you buy the seal and O-ring?<br><br>Thanks in advance<br><br>Ed
Old 03-05-2003 | 10:46 PM
97Dually's Avatar
http://dieselram.com/cgi-bin/ultimat...c;f=3;t=000360<br><br>This is the thread I found with the info on the Seal part number AND where to get it. Also contained is the instructions for replacing the seal. Thank Gosh for the internet and great guys willing to share info!! <br><br>TJ
jimbo486
05-08-2016 06:07 PM
jragan
09-05-2007 11:04 PM
BC847
10-30-2006 06:26 PM
Homestead
04-06-2006 03:58 PM
yomitch
04-21-2003 06:28 PM
Quick Reply: Leaking Vacuum pump?
