Leaking Oil Pan Gasket
A pain in you know where!!!! Try tightening the pan bolts and maybe it will slow down or prolong the agony. Could it be the dipstick tube or turbo oil return line???
Its not that bad. You need to take off the 4,5 and 6 valve covers. Then disconnect the motor mounts and jack the motor up as far as it will go. You can either just change the gasket, OR if you want to pull the pan, you will have to reach in and disconnect the oil pickup, and then the pan will come completely out.
The way I do them, is to block the back wheels and jack the front of the truck up as high as I can get it, place stands on the frame rails about mid door. I remove the front wheels and let the front end hang. Remove the cooling fan and shroud along with the last three valve covers, now you can remove your motor mount bolts and jack the engine out of its seat, remove the pan bolts and drop the pan, reach in to unbolt the pickup tube and pull the pan/tube out as one deal. Its a pain, but not real bad.
jack stands under the frame and a cherry picker loosing pass side motor mount and trans crossmember bolts and about 1 1/2 hours you can be done did it last friday with a little help one person in front of axle and one behind we did have the head off though and fan shroud loose
The_Head
11-05-2011 07:22 PM
bostongsx
09-25-2006 11:25 PM
Common
08-24-2006 06:31 PM
redramnc
12-16-2004 08:53 AM
