Leaking lift pump
Leaking lift pump
When I pushed the prime button, the lift pump started to leak fuel. It was just a few drops and it only leaked when I pushed the prime button. Fuel pressure is OK, 25psi at idle, and 32psi at 2500 RPM (no load). Should I replace the pump, or is this normal? Thanks for any help.
The only replaceable part on the lift pump is the o-ring that seals the primer button. Best to remove the pump to replace it.
If I were to go that far I'd be tempted to replace the pump and keep the old one for a spare.
I just came looking for the same info. I saw a few drops on mine today when I used the primer button. Could that button leaking also be leaking air back into the system?
I was messing with the starwheel yesterday and today I went to start it up and ran rough for 20-30 seconds then died. Had to prime to start. This has happened everytime I have messed with the starwheel, but I don't quite understand why??? There is definately air getting in the system, but I don't see why this would set it off. I have replaced the lines all the way to the tank, checked the tank module and replaced the overflow valve, so I think the lift pump is the only thing left.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
