Leaf springs???
Old 02-05-2007 | 09:49 AM
nates90's Avatar
Leaf springs???
Hey guys, I was just wondering what the stock number of leaf spring there are on a 1995 2500....because i only have 4 leafs with the bottum one being pretty thick....just seems a little light duty if you know what i mean...what you guys think.
-Nathan-
Old 02-05-2007 | 11:12 AM
mainer's Avatar
i've only got 3 in my 98 quad cab short bed 4x4
Old 02-05-2007 | 11:18 AM
TheBigNasty's Avatar
IIRC 4 is right. Now my new springs....... but the ride is .
Old 02-05-2007 | 04:04 PM
nates90's Avatar
What do you guys recommend....adding leafs...or airbags....and where are some places to get some good deals?
-nathan-
Old 02-05-2007 | 06:26 PM
Beefmaker's Avatar
I really liked the air bags I had on my last truck, 1/2 Ton Chevy 4x4, they were made by Air Lift if I remember right. They added about a ton of carrying capacity when pumped up but didn't hurt the ride when aired down.
Old 02-06-2007 | 09:35 AM
nates90's Avatar
Do i have overloads???
I am looking at some air bags now for my truck....but they have two different setups....one is for truck with overload and the other is for truck without overload? How do i tell if my truck as overloads.
-Nathan-
Old 02-06-2007 | 11:14 AM
Need95-00CTD's Avatar
An overload sprig is a spring that does nothing until you sag enough to engage the spring. i.e. If your at 500lbs payload it does nothing, but once you hit 1700 or whatever, it compresses the standard spring enough to engage the overload. It can be in 2 styles, one where the bottom spring is very thick and straight on the bottom (ends not touching the upper springs), or with a top spring curved heavily but not attatched to the bottom springs and when the suspension sags it hit a bumpstop engaging the spring. Hope that helps.
-Matt
Old 02-06-2007 | 12:41 PM
Crimedog's Avatar
The overload is a spring above the main leaf pack that has two bump stops as described above. The main 4 leaf pack is standard, including the thick straight one at the bottom. Some people take the bottom one out to improve the ride a bit. I vote for air bags. I added an extra spring and it made it ride a lot rougher. I don't mind it, but someday I'd like to get rid of it and do some bags.
Old 02-06-2007 | 03:13 PM
JKM's Avatar
JKM
If anyone wants to come up and trade me for a set of stock leafs , you can have mine... I have 6 or 7 leafs per pack , not overloads , just extras that someone had a spring shop put in... talk about riding rough... I have 1200lbs worth of weight right at the tailgate , for winter , and the truck is just about down to being level now...
Old 02-06-2007 | 03:40 PM
Adam3291's Avatar
I have a friend that has a 95 and he is looking for two sets of leafs and overloads. He overloaded is truck to many times while pulling hay with his gooseneck and ruined his.
97catintenn
05-28-2010 08:29 PM
95turbo4wd
12-12-2007 05:59 PM
Joe T
16
06-12-2007 12:11 AM
Eagle Driver
04-13-2004 08:26 AM
RAMTECH
03-26-2003 11:15 AM
Quick Reply: Leaf springs???
