KDP Question
Old 12-24-2010 | 01:30 PM
IanM's Avatar
KDP Question
Hi all,
If I were to look at a 12v that has not had the KDP taken care of, would a grimy gearcase be a sign of KDP damage? Or would it be more obvious, like a massive crack?
Thanks,
Ian
Old 12-24-2010 | 02:27 PM
banks twinram's Avatar
Usually they bust underneath the fan pulley you cant see it without taking the fan off. The front crankshaft seal usuallyleak on these and is hard to tell if ith that seal or a busted front cover. If they are saying they fixed the kdp they should know if it had already fallen out or not. Theres one bolt under the fan pulley that will either have no threads left in it or broken completely off if the kdp fell out obe time
Old 12-24-2010 | 03:10 PM
IanM's Avatar
The current owner of the truck wasn't sure if it had been fixed, but there is a TON of crap plastered over the gearcase.
The truck runs perfectly, so I'm assuming that the KDP hasn't dropped yet (or fell out and dropped into the oil pan). It has 400,000 kms on it....
Old 12-24-2010 | 05:51 PM
patdaly's Avatar
Could also be the case bolts have loosened and allowed a leak.
When mine went, it took out the top of the case, over the IP gear.
Yea, you could tell it............
Old 12-25-2010 | 10:56 AM
kandgo's Avatar
It is just leaking. I bet it has not been done. That kind of mileage, I bet it is either in there tight or fallen to the bottom.
Old 12-30-2010 | 10:51 AM
Diesel_Power_2's Avatar
Smile Re:kdp
Hi IanM,
I just bought a 97 with 455KL and it had Major I mean Major crap thick Oil caked on the case and underside of the entire truck. I bought it without doing a preliminary check other than a quick run around the block and it was/is still running strong.The price was low but needed alot of work as I found out. O_well most done now.
I have steam cleaned everthing and it is looking pretty good and will be doing the kdp very soon. I was quoted $400.00 to do it at a shop. I am ok with a wrench and would prob do it myself but I have no garage and am in a apt. so..
Anyhow less than 300,000 miles on a 1,000,000 engine is decent life left I would think.
Old 12-31-2010 | 04:46 PM
shorthair's Avatar
Originally Posted by Diesel_Power_2
Hi IanM,
If you can/are willing to do the work yourself you can save about 360 of those dollars with a about 3-6 hours work.
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
Deereguy
02-12-2004 06:44 PM
turfquip
11-12-2003 10:49 AM
1320
07-06-2003 03:41 PM
Quick Reply: KDP Question
