KDP pin absence??
Old 07-09-2004 | 11:30 PM
DZLPWR's Avatar
Question KDP pin absence??
Does anybody know if its a big deal that im not replacing my KDP pin after its fallen out? Im doing a KDP failure repair and dont have a new pin. Big deal or dont sweat it?? Thanks -Jake
Old 07-10-2004 | 12:09 AM
Crimedog's Avatar
I have always read and heard both sides, one that it is only there for an alignment for assembly, and the other that it actually does bear lateral stress to keep things alligned. I would put a new one in and tab it. Another thought that i have always had is why not tap the hole and put a bolt in with some red lok-tite? That way you KNOW it isn't coming out. Just a thought....
Old 07-10-2004 | 02:01 AM
infidel's Avatar
It's important that the case doesn't move to keep your timing set. When you figure the weight of the injection, vacuum and steering pumps plus the torque that the cover is under to turn these pumps you realize that the more devices to keep the case in place the better. There are actually two dowel pins, I wouldn't put one back together without both of the $2 pins.
Old 07-10-2004 | 08:27 AM
kandgo's Avatar
I would agree to put back in, I have seen them missing and the new one would not go in without loosening the housing,which tells tha they do move. Goodluck,,Rick
Old 07-10-2004 | 12:03 PM
dalton4's Avatar
I agree fully with Infidel. He well covered the "whys" for using the pins.
Old 07-12-2004 | 08:29 AM
gunracer1's Avatar
i put mine back together without the top dowel pin, i wish i had put one in. i have never had any problems in the last 35k but i would feel better if it was there. mike
Smokin96_12v
10-12-2009 07:39 AM
West Coast
05-26-2007 10:22 PM
bigragu
10-17-2005 04:07 PM
Crimedog
03-11-2004 01:54 PM
WTTD
06-05-2003 09:45 AM
Quick Reply: KDP pin absence??
