View Poll Results: Have you gotten your KDP fixed?
Yes, tabbed
68
53.54%
Yes, used the jig
17
13.39%
No
33
25.98%
No, and have had it fall out and break something.
7.09%
Voters: 127. You may not vote on this poll
KDP: Have you tabbed, used the jig, or not done it at all?
Advantage to the jig is it's quick and easy.
Jig bolt blocking dowel pin.
mahamonkeymojo (05-24-2019)
Not if you do it right.
What you do is pressurize the crankcase though either the oil fill or dipstick tube with an air compressor (5psi max) or a vacuum cleaner on blow with the blowby tube plugged.
They do over at TDR but the shipping for a jig coming and going usually costs more than it does to buy your own from Harold at rvhvnfn@juno.com or 208 850-8749
You could also try PMing member Wannadiesel, https://www.dieseltruckresource.com/...=newpm&u=21682 he jigs dowel pins for fun, believe he is in the NE.
You didnt have an option listed for me. Mine fell out. I had no idea that is what it was. It ran for a good hour before I pulled it apart and found out it was the dowel pin All it did was make racket, and it fell out on the floor when I pulled the timing cover off. It is now tabbed and back in its home with a lesson learned "ill get to it someday soon" may not be soon enough
Eric
Eric
I had to replace the timing case on mine, which has the "stepped" dowel pin hole... keeps it from walking out in the future. I also put a new dowel pin in the block... installed with red loctite.
