KDP got me!!!!!!!
Old 12-22-2002 | 09:46 AM
  #31
berner's Avatar
Re:KDP got me!!!!!!!
Great time to do it pprash. You have to use a mirror to see the pin with the rad and shroud in. Lots easier on the arms not having to fight around the shroud. Install the seal before you put the timing cover on. I didn't and it was a b**ch. Good luck.
Old 12-22-2002 | 09:54 AM
  #32
PPrash's Avatar
What is the trick to getting the vibretion dampnet off? (I assume I will need a puller) Also, can I post a pic directly to this forum site without having to put it on a server?
Old 12-22-2002 | 01:23 PM
  #33
mymaur's Avatar
Okay, here is the question of the day. What in the *&amp;%$# is the KDP?? I have two 95s both with CTD. Could someone enlighten me. THis sounds pretty serious. ??? ???<br><br>Thanks.
Old 12-22-2002 | 01:45 PM
  #34
richard's Avatar
The KDP is a dowel pin in the front of the motor behind the timing cover that over time walks out of the hole in which it is pressed into from the factory. When the dowel pin falls out, if your lucky, just breaks the timing cover and then you just have a large puddle of oil under your truck. If your not so lucky-read as most of the time-the dowel pin falls out and finds its way into the timing gears and does all kinds of hellacious damage! Just surf around the site a while and you might find some pictures of the carnage this little pin is capable of.
Old 12-22-2002 | 02:04 PM
  #35
mymaur's Avatar
Richard,<br><br>Thanks for the reply. Now can you or someone else tell me where to look or how to find it. I do have the factory service manual, perhaps someone can tell me a page or paragraph in there so I can find this. Both my trucks are here now for the holidays and it would be a good time to do the repairs.<br><br>Thanks.
Old 12-22-2002 | 03:06 PM
  #36
atc250r's Avatar
Try these two for some info:<br><br>http://www.phantomcycle.com/kdpfix.html<br>http://members.aol.com/_ht_a/hrrs994/kdp/<br><br>John<br><br><br>
Old 12-22-2002 | 03:39 PM
  #37
mymaur's Avatar
Thanks guys for your help. After spending the last couple of hours reading your info and checking various web sites, I have figured out where it is and what may be the best way to tackle it.<br><br>Is there a way to determine the pins current position without removing the cover?
Old 12-22-2002 | 04:16 PM
  #38
pappyman's Avatar
[quote author=mymaur link=board=16;threadid=8168;start=30#83580 date=1040593185]<br>Thanks guys for your help. After spending the last couple of hours reading your info and checking various web sites, I have figured out where it is and what may be the best way to tackle it.<br><br>Is there a way to determine the pins current position without removing the cover? <br>[/quote]<br><br>The short answer is no...the long answer is try the fix with a KDP jig kit if you dont hit the dowel then your home free if you do hit the dowel remove the front cover and repair as needed<br><br>.
Old 12-23-2002 | 12:19 AM
  #39
dodgeman01's Avatar
I guess if you lose you KDP and it cracks the gear housing then you are sunk and need to send it to a diesel mec. Is that right. My friend lost his and there is a small crack. he adds a 1/2 qt a week. it is not too bad but he wants to do it himself because his money is really tight. he just got married to a HOT chick and has very little money. he even did not have christmas because of his money problems.<br>what is the price to fix this and is there any way to weld it until he can get some money?<br>thanks for me and my friend<br>DM01<br>P/S don't tell his wife but I bought his wife a gift for him because he is my best friend
Old 12-23-2002 | 06:54 AM
  #40
bulthisl's Avatar
That would make it very easy to do.<br>If I had the front off that's what I would do.<br>That way you don't need mirrors.<br><br> : Eddie : 8)
Old 12-23-2002 | 07:15 AM
  #41
Rammin On's Avatar
The crack in the housing will continue to migrate until the housing cracks in half ... there is about 100# of injection/vacuum/steering pump hanging from that housing.
Old 12-23-2002 | 02:55 PM
  #42
pwabbott's Avatar
[quote author=csaverline link=board=16;threadid=8168;start=0#78938 date=1039623981]
TI have pics but i need to figure out how to resize them to get them to fit on here.
[/quote]
If you have a photo editor, open the picture in the editor. Resize the picture to not over 7 inches, then set the resolution at 72 dpi and save. Some editors have an option of save for the web. This option sets resolution for you at 72 dpi.
I use Photoshop Elements (Adobe) You probably have a basic editor which came with your camera.
sootnsmoke
01-05-2012 08:55 PM
Dale M
03-05-2011 03:40 PM
Smokin96_12v
10-12-2009 07:39 AM
bhoff1175
06-07-2006 10:19 PM
Begle1
07-13-2005 04:13 PM
Quick Reply: KDP got me!!!!!!!
