KDP fixed and truck retimed
Old 07-02-2005 | 12:18 PM
Bobcat698's Avatar
Cool KDP fixed and truck retimed
Well got my truck back yesterday. The shop had a hell of a time getting the cam gear back on correctly..
Anyways I picked it up and noticed my steering was now REALLY easy and the brakes were firmer.. Not sure why..
Also, they re-timed the engine to 16º.. It runs very nicely. I can now hit 109MPH without EGT's getting to hot (closed course, trained driver)
Truck now also runs much cooler.. The radiator was packed full of crap so we steam cleaned it out. Also flushed a bunch of crap out of the inside of the radiator.
We put in a new thermostat as well.
It used to get to 190 in general traffic.. I grossed 14,870 on the way back from picking it up (I pulled another truck back home with me) and it ran about 150º.. I'm pretty amused.
Overall I'm happy other than the fact that the truck still leaks.. Not sure where from though.. somewhere from the cover.
Old 07-02-2005 | 03:28 PM
TxDiesel007's Avatar
Glad to hear you got it back again
I have yet to do my KDP but believe me its priority!!..
Tx
Old 07-02-2005 | 03:50 PM
Txwelder's Avatar
Its not a hard fix, I see too many saying they are going to do it ,but man, what a risk! Good luck.
Old 07-02-2005 | 04:55 PM
Dshiftff's Avatar
Do a little work now, or do alot of work later... The way to look at the KDP problem
Old 07-02-2005 | 05:56 PM
Smkndzl's Avatar
sounds like the thermostat that was installed is defective , you should be getting to at least 180 , if they put a 180 thermo. I would check it out , 150 is not enough heat for that engine.
Old 07-04-2005 | 09:10 PM
Ggg's Avatar
Ggg
Hey Garrett how was your trip back from Indy? I just did my KDP today. Mine showed no signs of coming out, but I did the bolt keeper anyway. I was wondering how yours turned out while I was working on mine. I must admit it is a load off of my mind fixing that KDP. Now I need to rebuild my trans.
Old 07-05-2005 | 08:53 AM
Bobcat698's Avatar
It was a little cramped going back home in the Saturn.. I'm just not built to ride in a car
Made good time though and got back and forth from Indy in the amount of fuel it would have taken me to get to CHICAGO with the truck
Old 07-05-2005 | 08:54 AM
Bobcat698's Avatar
The engine temp is running just over the start of the "normal" range on the temp gauge.. Probably not 150º now that I look at it.
8Lug_hotrod
04-18-2021 08:07 AM
Smokin96_12v
10-12-2009 07:39 AM
esde
03-21-2009 02:26 AM
jwtuc
14
03-22-2004 08:35 PM
mikeh
0
01-20-2003 01:15 PM
Quick Reply: KDP fixed and truck retimed
