KDP Fix and timing adjustment.
Old 07-29-2009 | 06:19 PM
Hotwheelbill's Avatar
I have two questions. 1) When I do my KDP fix, would that be a good time to advance the timing......would it make it any easier to do?
2) If I had someone else advance the timing, how much should it cost?
Old 07-29-2009 | 07:37 PM
infidel's Avatar
It makes it a little easier to clean the shaft and gear with the cover off but it's not all that hard to clean them though the removed oil fill hole either.
Going rate to adjust the timing the right way is about $150-$250
Old 07-30-2009 | 12:01 AM
first4age's Avatar
That's what I did. It's easier to adjust and easier to find TDC since you have some marking on the gears and use the drop valve method to trully find TDC.
If I had to do the drop valve method the first time without being close to TDC, it would be scary as hell.
Old 07-30-2009 | 12:02 AM
first4age's Avatar
Oops, did it myself so I have no clue. Did all the mods myself and this is my first diesel engine.
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
TIMMY22
03-22-2009 08:39 PM
crazylunker
12-06-2006 11:26 PM
GR40RCapri
06-25-2006 12:53 AM
Quick Reply: KDP Fix and timing adjustment.
