THE KDP and associates
Old 01-14-2008 | 09:44 PM
Ru rammin 2?'s Avatar
Angry THE KDP and associates
I pulled the shroud and fan pulley after spraying everything with brakeclean and the oil leak is still a mystery. I didn't want to pull the timing cover till I know where to get a kdp fix and how much it will cost me to do so. I tried to pickup a timing cover seal today but that endeavor didn't prevail. I found that autozone can order one for a relentless $52 and change. Does the fix-it kit come with this seal? Mine hasn't been fixed by the way seeing as there was some paint on areas of that gray silicone. Any and all info is appreciated.
Old 01-14-2008 | 09:56 PM
traindrv's Avatar
My kit came with the seal. tst products(KDP-03) $48
Old 01-14-2008 | 10:23 PM
displacedtexan's Avatar
The TST kit comes with Permatex, tab, longer bolt, crankshaft seal, and EXCELLENT instructions.
Old 01-14-2008 | 10:25 PM
leprechaun's Avatar
The TST kit comes with silicon sealant which will make a new cover gasket and a new crankshaft seal along with the tab and longer bolt for the KDP.A good value at about $50.
Old 01-14-2008 | 11:07 PM
Sure sounds like it. where can I find one of those? I need one. Is that all you need? It sounds almost too good to be true.
Old 01-14-2008 | 11:24 PM
trksrfun's Avatar
on the cummins at work it was leaking oil, tightened up the timing cover bolts and that solved that. maybe with some luck thats all you need to do as well!
Old 01-15-2008 | 07:02 AM
All you need but the tools
http://www.tstproducts.com/index.asp...PROD&ProdID=64
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
OHFarmboy
06-23-2006 08:59 PM
Pickle
12-11-2004 06:48 PM
WalkingHorse77
03-19-2003 12:27 PM
Quick Reply: THE KDP and associates
