Kdp
Old 10-24-2005 | 02:39 PM
running4bhs's Avatar
Kdp
Ok I just got done tabbing my KDP yesterday and I am happy that I did. Got the gear housing cover of and found the KDP back out about 1/2 inch. Got a hammer and punch and tapped it back in and then thought what’s this thing for. So I wanted to know what does this pin do, and when people remove it does it cause a problem at all. Thanks guys
Old 10-24-2005 | 04:41 PM
turbo thom's Avatar
So when the cover is removed for replacement, should the pin be replaced if it is no longer there? What say you? Does it need to be there? If not, why was it use in the first place?
Old 10-24-2005 | 06:41 PM
Ok I think you miss understood what I was saying. I understand what happens when the pin drops, but I wanted to know what the pin is for and what happens when people romove this pin.
Old 10-24-2005 | 06:57 PM
infidel's Avatar
There are actually two dowel pins, only one falls out and causes a problem.
It's absolutely necessary that both remain in place to keep the case from shifting, the case hold down bolts are loose in their holes compared to the dowel pins.
Old 10-25-2005 | 02:09 AM
Ok so if you remove the one pin its not a big deal? Also this pin keeps the cause from shifting, Ok think Ive got it thanks
Old 10-25-2005 | 07:44 AM
turbo thom's Avatar
That's it Bill. That's the point I was making. A lot of times I will post a question for the "beginners" to ponder. There seems to be a lot of redundunt questions.
Old 10-25-2005 | 08:42 AM
Greguw's Avatar
Smile Tighten that cover...
I'm new to the site and I just did my KDP ... my cover bolts were very loose ... I took out the bolts and cleaned and relock-tighted the bolts ...I'm glad I did that , especially the ones behind the timing gears .
Later
Greg
Old 10-25-2005 | 09:34 AM
infidel's Avatar
It could be a big deal, leave the pin in place. Most times it's impossible to pull it out anyway. If you could pull it out it would have fell out on it's own by now.
Many people don't realize how much weight and torque the case is under. It supports and keeps your injection, power steering and vacuum pumps aligned.
If the case shifts due to no dowel pin it will change the way the gears mesh up and cause rapid wear. It can also change your timing.
Old 10-25-2005 | 11:38 AM
Ok like my first post said I "Tabbed My KDP." I just heard about people taking theres out and thats what I was asking about.
Old 10-25-2005 | 01:32 PM
Greguw's Avatar
Smile Re: KDP
I could have removed mine completly ... As a former wench , I also asked my self about the stress that is transfered to the cover ...I had to loose the main cover bolts in order to get the pin all the way in .
I definitely agree with Infidel ...The the pin is a vital part of the big picture ... That pin has pretty close tolerance's I would assume it dose absorb some type of load from all the pumps .
But if you seen how lose my cover was I would say your motor will run for some time with out it.
Later
Greg
sootnsmoke
01-05-2012 08:55 PM
Smokin96_12v
10-12-2009 07:39 AM
SjLingenfelter
07-19-2003 05:14 PM
WalkingHorse77
03-19-2003 12:27 PM
gofastman
03-19-2003 10:29 AM
Quick Reply: Kdp
