Kdp
unless the jig has been used, you really cant tell till you take the cover off.
The lift pump tick is a weak spring in there. The plunger then "floats" not following the cam lobe back every revolution. It eventually may not start and leave you walking home.
the only way i could think of telling (and it's not 100% at all) is if the cover has rtv sealer sticking out. Thats not really a good enough judge either, it's best to just get the kit and take care of it anyway, u get a new crankshaft seal to replace so it's worth doing it.
sootnsmoke
01-05-2012 08:55 PM
