Ive lost all low end power.
Old 09-08-2007, 02:52 PM
notomas's Avatar
I went down and purchased all new vacuum lines, and connectors.
With a manual vacuum pump I checked each stock line seperately, if it had any leaks I couldnt find any. So I replaced them all just to be sure.
How can I tell if the timing on the fuel injection pump is off, every thing else seams to be as it should?
Old 09-08-2007, 05:30 PM
gmctd's Avatar
Ok, good deal on that, eliminates the usual stuff.
How hybrid is your HX-35?
Old 09-08-2007, 06:15 PM
notomas's Avatar
its a 35/44
or at least thats what the shop said that I bought it from.
Old 09-08-2007, 11:08 PM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Badly slipped timing???
Old 09-09-2007, 06:50 AM
notomas's Avatar
Im not sure what to look for. Wouldn't it back fire and stuff like a gas engine for slipped timing?
Old 09-09-2007, 08:36 AM
notomas's Avatar
I think it is my new TCC. It is engaged and wanting to pull the secont I put it in gear. Thanks for all your info and suggestions. My truck is running better from all the stuff I checked and serviced. Now I need to reset it up to pull from the start.
Old 09-09-2007, 04:33 PM
gmctd's Avatar
Try a basic 35 for better spool-up with the low-stall convertor - that hybrid is wanting more exhaust energy at higher rpm, which you lost with the 'tight' TC
A#10 plate would help, but you'll also get bunches of down-low smoke B4 the turbo spools up over 5psi
Old 09-10-2007, 10:31 AM
notomas's Avatar
Thanks, I still have the stock turbo, I will try it
Old 09-10-2007, 12:56 PM
lgp9999's Avatar
I would think not. Backfiring is caused by fuel getting into the exhaust system and combusting in there. Diesel does not combust... it burns (even then, not as easily as gasoline). Thus the reason that you never hear a diesel back fire.
Old 09-10-2007, 01:04 PM
notomas's Avatar
ooo, what are signs of a slipped timing on a diesel
Old 09-10-2007, 05:05 PM
schoust's Avatar
White smoke and low power.
mitm
10-21-2010 01:25 PM
u.s mma
04-06-2009 06:08 PM
na4now
12-10-2008 03:43 AM
spitzair
01-24-2006 03:42 PM
ClawHammer
08-07-2004 08:49 AM
Quick Reply: Ive lost all low end power.
