Injector troubles Grrr
Hey guys,
Im working on a truck thats been sitting about 3 months. I was trying to get the injectors out...ive tried to make a home made puller and used vice grips but i just cant get them out. Any thoughts
stuck injectors
You could try to loosen the hold down nuts on the injectors a few turns then crank the engine over the compression should pop them free. good luck!
If they are stock injectors, cut a piece of 3/4'' pipe 1-3/8'' long, slip it over the injector then use one of the truck's wheel lug nuts threaded on to the fuel line threads to pull it out.
The pipe will push on the head while the nut pulls on the injector. Works every time.
I removed the fuel lines and the locking nuts from the injectors, then re-installed the fuel lines a couple of threads. I then used a short prybar to pop the injectors out using the head as a fulcrum. I've done this many times and never had any problems removing the injectors. Position the fuel nut so that the bar is under a corner and don't push the bar into the injector body or you may damage the threads.
big red psd cc
11-21-2005 05:09 PM
