injection pump?
Old 11-13-2010 | 06:22 PM
jonny mopar's Avatar
injection pump?
i just bought a 95 dually 5sp 4x4. it was running on 5cyl. i narrowed it down to #1 cyl. I am not sure what they are call, but its on top of the injection pump ware the injector lines screw on to. they have the 2 bolts holding them in. But anyhow, the #1 one was broke in half. i am guessing this is the problem of it running on 5. i am guessing it got water in it and hydro locked it and busted it in half. I drained the filter and sure enough it was about a 1/4 filled with nasty rusty water.
SO can i buy one of them or will i have to buy a whole friggen pump?? i havn't been able to find any on ebay, craigslist, or on here.
Old 11-13-2010 | 06:30 PM
Tate's Avatar
You can get the barrel replaced, but it will need to be calibrated afterward, so you may as well send it to a pump shop and have it completely gone through.
Other option is buying a used one. You can pick up a used pump for $300-500 in many cases. And being that your truck is a 175hp engine, you can get a 180 or a 215 pump as an upgrade.
Old 11-13-2010 | 06:43 PM
any 94 to early 98 pump will work thoe? what does it cost to have a pump gone threw? are the pumps a pain to get off? i have never taken one off before.
Old 11-13-2010 | 07:22 PM
Tate's Avatar
Take about 2 hours to get the pump off at a steady pace. Only special tool you need is a gear puller (steering wheel puller) to get the gear off. Not sure what it would cost to have your pump repaired, that you'll have to phone around and see. I am almost certain a used pump will be the most economical choice. Any 94-98 pump will work, but the 96-98 are a bit better in terms of cam design. If you go to Competitiondiesel.com, there is a large classified section there, usually with several pumps for sale at any time.
Old 11-14-2010 | 08:40 AM
blackimpala's Avatar
I understand that the pre-96 pumps sometimes had a problem with the barrels I would look for a 96-98 pump.
Floyd
Old 11-14-2010 | 09:50 AM
GAmes's Avatar
I just had my pump repaired for an oil leak and inspection of the rest of the pump. No other parts needed than a $36 rod and the gaskets to reassemble. The labor charge was $940. The upside is I know all my internals are good and illustrates that ULSD DOES NOT need additives.
tommurray
02-23-2014 10:38 AM
billygoat02
12-29-2005 11:03 PM
adgr71
11-28-2005 07:34 PM
Yukon Dodge
18
07-01-2004 10:08 AM
cheng
06-22-2004 12:01 PM
Quick Reply: injection pump?
