Im getting so tired of this.
It seems like every time my truck is finally running right something goes wrong. For the last couple of days when I star my truck it idles for about a second and then dies after about 2-4 times of this it will start then run fine. If I giver her a little throttle she will start right up most of the time but not all of it. Well today when I turned it off in the drive thru it would not start at all after about 10 attempts and people getting ****** behind me it started and I held her at 2k for a few seconds after that she is fine. I’m getting so tired of this it was doing great for about a week now this. There is a little bit of something on the ground were I park but it rained and Im not sure if its old or new if anyone has any ideas im all ears. Thanks for any help you guys can give.
Chris
Chris
Check rubber fuel lines around pre heater/strainer, they get old and crack. Also, have you changed fuel filter lately? Did you get it back on right, maybe debris in seals causing fuel leak.
Its a strech, but check the fuel solenoid, it will cause truck to die, but won't cause any leakes. Just things from my experinece.
This type of stuff has been happening since I replaced the p pump. Could this be overflow valve? Has anyone ever gotten a new one that was bad? I am also thinking it is the solenoid. Tonight im going to turn key to run pull the solenoid by hand and se if she starts ill keep you informed.
Chris
Chris
Does it smoke white when it does start up, if so you probably have a fuel leak, or your timing slipped, those are easy to check for. Fuel filter may be plugged, overflow valve may be shot, but not likely since it's new. Solenoid could be it, if you want pull it off and lift it manually by hand, that will give you a yes or no, but it could be the relay too.
pulled the solenoid and it started in about 3-4 seconds. so i guess thats it now i just have to fix it any idea whats wrong? Is it not pulling far enough? or maybee something else.
Chris
Chris
i had the solenoid go out on mine so i just made a bracket for the pump and made it a cable shut off with a universal choke cable for a tractor........anything to get rid of electronics thats why i bought a 12 valve
Look on ebay for those clear mercedes fuel filters with the brass inserts on the ends. Install one before the inlet on the IP if you can find a hose to splice. Great for spotting air in the lines.
PDR sell new solenoids at a good price. My Fuel solenoid came apart in to several pieces, others just get crud in the boot, because it is torn or gone, others just go bad, I'd get a new one and you'll be good for another 200k.
Chris
Chris
another stupid thing that tends to cause a headache is the water separator unit on the fuel filter...it likes to leak..that will make ur engine die and make things hard to start..i am using a solid filter for years now carquest # 86395...its a fleet filter...costs 8$ rather than 30$
Mine Did The Same Thing ..i Change The Selnoid And The Relay And It Would Start Sometimes And Then Not Others There Was A Thread On Here That Told Me To Check The Blue Wire On The Battery Positive On The Driver Side ..they Get Bad About 2 To 3 Inches From Terminal...i Just Cut It Off And Stripped The Wire And Put It Back On The Battery And Works Fine Now
Could Have Saved 400 Dollars Might Try That First
