Idle Adjustment
Old 02-19-2007 | 02:06 PM
74dart's Avatar
Idle Adjustment
My throttle wasn't fully opening only allowing me 2700-2800 rpm instead of the 3200 i should get. I adjusted the linkage going to the back of the pump. Now it idles around 1000 rpms is there a way to adjust the idle or do i need to adjust the linkage back alittle.
Old 02-19-2007 | 03:55 PM
TxDiesel007's Avatar
u can adjust the idle
behind the injection pump there is an idle adjustment screw, U need 2 10 mm wrenches to get to it, one to loosen the nut at the bottom, and the other one to adjust and turn the screw to get ur idle to where it needs to be. If you have long arms, this will come easy for you, if not, well the best way to tackle it is with a step ladder from the left side of teh truck.. The picture in the link below will tell u what i mean..
Hope this helps, it has most everything u need to know...
http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Rick
Old 02-19-2007 | 04:42 PM
JKM's Avatar
JKM
FWIW , I find it MUCH easier to lay ontop of the engine and look straight down the back of the pump , you can actually SEE what your doing there , instead of doing it by feel only.
Old 02-19-2007 | 04:50 PM
TIMMY22's Avatar
I have an addition to make to step 3. .....
It talks about using a 5 gal bucket to stand on from the drivers side while you adjust. What it fails to mention is the part when you are are on the 5 gal pail and you slip and the pail pops out from under your feet and you smash your chin on the battery terminals.
Old 02-19-2007 | 10:25 PM
Tate's Avatar
Is this part of the step mandatory, or purely optional?
FANZDSLPWR
07-09-2004 06:42 PM
apache
03-30-2004 10:17 PM
Timinva
06-26-2003 09:36 AM
Den052
06-21-2003 12:45 PM
Dusty 96
11-07-2002 03:39 PM
Quick Reply: Idle Adjustment
