I think i need a head gasket
my antifreeze is foam like there is dish soap in the radiator and it has the normal leak by the thermostat housing and it starded to use oil. where is the best place to get a head set.
Get studs. Not much more money than a new set of bolts and much better product.
Contact an A-1 stud vendor such as Haisley Machine. http://haisleymachine.com/index.php?cPath=304_308
ARP studs require machining the rocker towers. A-1s at most require die grinding a rocker cover or 2.
And use a bottoming tap to clean the block threads for ANY rework. Diesels force a huge amount of soot down the holes
Unless you absolutely want or need new head bolts/studs, there is a bolt stretch, go/no go gauge included in that # gasket set.
ted_pulliam
07-16-2009 11:33 AM
wildchild97
09-25-2007 02:44 PM
darrenG
07-13-2006 03:48 PM
