I lost speedo, tach, alt, A/C, O/D on bread winning work truck
#46
Originally Posted by greatwhite
Okay infidel. I'll bite. What is the sensor mounted above the harmonic balancer on my '93? I call it the crankshaft sensor, I suppose it could be a cps, crank position sensor. Hair splitting? The service tech called it a crank sensor. Don't remember what the FSM called it. But it was the problem.
Any rate, when the wires leading to it chafed, it grounded and no longer sent signal to my PCM/ECM/BCM//BBBB(blackbox behind battery) hence no charge, no overdrive,no a/c etc.
The Crank Position Sender is only on 24 valves and located by the starter.
royta
26
04-26-2016 08:23 PM
Need95-00CTD
40
09-17-2008 01:11 PM
banks-powered
01-08-2008 05:49 PM
