I lost speedo, tach, alt, A/C, O/D on bread winning work truck
Old 12-19-2005 | 12:57 PM
  #31
SHARPMACHINE's Avatar
Oh no my truck is doing it to!!!!!!!!!
Royta or ??,
Did you ever resolve it? Got any ideas whare I should start?
thanks
symptoms (early diagnoses)
No tach, speedo, alternater, and don't know what else.
Problem is intermitent, comes and goes, will run even when acting up.
This is on my 1996.
thanks
Old 12-19-2005 | 04:08 PM
  #32
greatwhite's Avatar
This is EXACTLY what my 93 did. In fact it is what led me to this great site. None of those things will work because the ECM doesn't recognize that the engine is running.
Check the wire to the CPS where it passes through the clip at the front of the head. the added weight of the connector pulls down on the wires slightly, and vibration over time wears through the insulation. The wire will then ground to the clip and presto, no CPS signal. Mine was worn ever so slightly, and that was enough to shut down all the goodies. I threw a new battery, alternator, ECM and many $ at the problem to no avail. A simple wire repair fixed it. Then i put loom over the wires where they run through the clip to eliminate the chafing. Hope your fix could be as simple as this.
Old 12-19-2005 | 04:25 PM
  #33
royta's Avatar
Originally Posted by SHARPMACHINE
Royta or ??,
thanks
This is on my 1996.
thanks
Yes, I did resolve the problem. However, it was not a replaceable part. It was somewhere in the loom assembly; I'm guessing somewhere between the firewall and where a part of the loom goes down the bell housing to the transmission/t-case.
I believe you should start with the ESS. Good luck.
Old 12-19-2005 | 10:22 PM
  #34
96D4x4's Avatar
no tach or charging
i would check all connections for corrosion, or loose connector i had similar problem and found it to be corrosion at ESS connector cleaned with CLR (mild acid), then flushed both sides with contact cleaner then blew out with compressed air then sprayed both connectors with Fluid Film (marine spray lube and corrosion inhibitor) fluid film also works good for Battery terminals. also check the wires to and from ESS it is located just above crank then to connector behind top rad hose. connector has 3 wires 1- (+8v supply), 2- (sensor ground), 3-(sensor signal 5-0.3v)
Old 12-20-2005 | 07:57 AM
  #35
I feel real stupid asking, but whare are these things??
cps
ecm
ess
the ess is just behind the top radiator hose??
thanks again
Old 12-20-2005 | 09:31 AM
  #36
infidel's Avatar
cps -- crank position sensor, shouldn't even be in the this thread because 12 valves don't have one
ecm-- engine control module, same deal, not used on a 12 valve
ess-- engine speed sensor, located at the lower engine pulley.
Old 12-20-2005 | 07:56 PM
  #37
96D4x4's Avatar
ecm
what do you call the box behind air box then? i know 12v does not have pcm because of mechanical fuel pump among other things, i thought is was called ecm because all it controls was engine components ? thanks in advance.
Old 12-20-2005 | 11:24 PM
  #38
JKM's Avatar
JKM
That is a PCM, powertrain control module , it controls more than just engine functions, it takes care of the tranny , instrument cluster , etc.
Old 12-21-2005 | 07:41 AM
  #39
Ok thanks everyone for the replies. I am going to try the to check the ess gap (do not have brass so will use paper or something non magnetic/matallic).
Someone mentioned unplugging the ess al togethor. What would this do? I would think it would only cause the tach to not work???
thanks everyone
Old 12-21-2005 | 10:01 AM
  #40
infidel's Avatar
thanks everyone
It will cause the PCM to think that your engine isn't running, most of your electronic functions will not work. In fact the only electronic function that will work is the wait to start and grids.
A 12 valve will run just fine without a PCM at all, just won't have the electronics and if an auto won't shift right.
A 24 valve will also run without a PCM, but remove the ECM and it isn't going anywhere.
Old 12-21-2005 | 11:02 AM
  #41
Anyone know what voltage or ?? I should see before and after the ess, just in case I do not find a bad wire, corrosion, or the gap to be out of adjustment? Or should I get a new ESS?
thanks again
Old 12-21-2005 | 04:04 PM
  #42
JKM's Avatar
JKM
I think if you search back through this post , Royota listed the voltage somewhere , i think it was 5V going to the ESS , but not sure how to test after that.
Old 12-21-2005 | 06:22 PM
  #43
96D4x4's Avatar
Pcm<ecm
i am confused my book (Haynes) calls the control module behind air cleaner box a PCM but i was told 96's don't have A PCM they Have a ECM. can anyone help me i don't like to refer to things by the incorrect names it drives me crazy when ppl do this and don't want to be one of them. and according to my Haynes manual voltage to sensor pin #1 reference voltage is 8v for 94-95 5v 96 and later reference voltage as per Haynes, and from sensor pin #3 at connector pcm supplied pull-up signal to sensor is 0.3-5v depending where the slot on vibration damper is to sensor
Old 12-21-2005 | 07:11 PM
  #44
infidel's Avatar
You really should spring the bucks and get a Dodge service manual instead of the one size fits all Haynes. All 12 valves don't need nor have an ECM.
The Dodge service manual is worth it even if it costs twice the price.
Order here> http://www.techauthority.daimlerchrysler.com/
Old 12-22-2005 | 08:20 PM
  #45
greatwhite's Avatar
Okay infidel. I'll bite. What is the sensor mounted above the harmonic balancer on my '93? I call it the crankshaft sensor, I suppose it could be a cps, crank position sensor. Hair splitting? The service tech called it a crank sensor. Don't remember what the FSM called it. But it was the problem.
Any rate, when the wires leading to it chafed, it grounded and no longer sent signal to my PCM/ECM/BCM//BBBB(blackbox behind battery) hence no charge, no overdrive,no a/c etc.
Quick Reply: I lost speedo, tach, alt, A/C, O/D on bread winning work truck
