hx35 compresser wheel torque spec?
i have resently bought a 60mm comp wheel for my hx35 and was wondering what the torque spec was on the nut holding the compresser wheel to the shaft?
thanks
thanks
I don't know but you can download a manual here that will tell you http://www.holset.co.uk/mainsite/fil...%20manuals.php
There was a guy on another website who said he broke off the end of the shaft tightening down the nut. So I guess that means don't use a three foot breaker bar to torque it down.
I opened it for you. Then i had to find it, and it was in another document called the service data sheet.
If it's a 6point bolt, then 133 inch lb, and 124 in lb if 12 point.
Hope that helps.
Joel
Hope that helps.
Joel
torque specs - 6 pt nut is 133 in. lbs and 12 point nut is 124 in. lbs.
http://www.holset.co.uk/partsservice...Data_Sheet.pdf
jivemother
06-20-2013 08:27 PM
