Humming Vibration?
Humming Vibration?
OK, this is the first problem I have had with my 98. Everything has been going great with it until the other night. I got in the truck after work, started it up and let it warm up for a bit. Drove out of the parking lot and got on the freeway where I accelerated up to 55MPH and noticed a vibration.
I promptly turned off the radio and air vent fan to better understand what this was. All I can offer is that it is a vibration/hum that is coming from what I believe to be the transmission area of the truck. I can further add that the noise only happens when the truck is in gear and rolling, usually when under a load. The faster I go, the worse the vibration/hum. Under 15 MPH it is unnoticeable.
Any ideas?
Any ideas?
U-Joint
I will definitely look into both of those, but I might have missed stating that the vibration/noise goes away while rolling and I put the transmission in nuetral... Would that still cause you to be thinking carrier bearing or U-Joint?
Thanks Timmy! I am so glad I am not focusing on the transmission! I am trying to locate the part/source for the carrier bearing, figuring I will try that first before the U-Joint. Or, do you think I should go the other way?
Any options here for an upgrade/BOMB?
1 Post
also, when carriers go they usually get hot! slide underneath after you just had it out on the road. carefull because they get real hot!
myfirsttruck
12-24-2007 12:39 PM
Ramirezh
13
09-29-2006 08:19 AM
