Huge Oil Leak!!!! Help!!!!!!
Old 08-24-2010 | 07:49 PM
Ken Collins's Avatar
Exclamation Huge Oil Leak!!!! Help!!!!!!
Ok so was out driving today and stopped to get some fueland i llook under my truck and its leak a lot of oil covering the front axle of the truck from what i can see it is leaking somewhere under the injection pump or the afc houseing very confused the truck seems to be running fine and all might seen a tad low on power but could just be me being paraniod anyways if anyone has any idea what it might be please help me out
Old 08-25-2010 | 07:00 AM
Tate's Avatar
Could be loose bolts on the AFC housing, could be a cracked gov housing, could be the timing pin plug fell out, tappet cover is leaking, oil line to the vac pump, etc. Best bet it is to crawl underneath and have a good look. Washing it off first would help. If its a real big leak, shouldn't take much run time for it to start showing again.
Old 08-25-2010 | 07:37 AM
patdaly's Avatar
https://www.dieseltruckresource.com/...ght=whackamole
Old 08-25-2010 | 01:16 PM
FlaCracker's Avatar
Could also be the oil feed line to the IP or the tappet cover behind the IP. Another problem area is the rubber seal between the vacuum pump and the power steering pump.
Old 08-25-2010 | 08:56 PM
thanks for the help guy found the problem afc housing was loose and from a bolt breaking
Old 08-26-2010 | 12:07 AM
DodgeMonkey's Avatar
Do your KDP too if you havent already done it, as this could lead to another, much more expensive leak.
4969joes
03-20-2010 04:50 PM
slimpicken
10-27-2009 07:01 PM
jeremy judge
16
03-18-2007 07:12 PM
Underpsi
21
06-29-2006 07:30 PM
smokeyram
10-06-2005 04:12 PM
Quick Reply: Huge Oil Leak!!!! Help!!!!!!
