How much smoke is normal?
Old 03-21-2007 | 03:44 AM
ScottN's Avatar
For a stock truck...
If I gun it at higher RPM's, I can get a fair amount of black smoke.
The truck is, as far as I know, basically stock engine wise.
It can be a little excessive if you are towing a heavy trailer or something up a hill. Seems like a lot of smoke for a stock truck, BUT it is only at high RPMs with lots of throttle, and otherwise it runs excellently, and gets good fuel economy.
Old 03-21-2007 | 03:02 PM
Clayten's Avatar
DTR's Toad Wrangler
Just a thought but how clean is your air filter?
Old 03-21-2007 | 03:08 PM
Lil Dog's Avatar
High Rpms will get some smoke out of the stock 97. Typically runs over 2600 Rpm will get the truck to the wastegate setting and will continue to fuel for peak HP. This will produce some smoke. Now large amounts of unclear smoke may be an indicator of late timing or plugged air/exhaust components.
Old 03-21-2007 | 05:49 PM
ScottN's Avatar
I think I may have found (part of) the problem. My batteries crapped out on me today, and while changing them, I saw that one of the exhaust manifold gaskets has migrated.
On closer inspection, I have two blown exhaust manifold gaskets. DUH. They aren't super blown (like there isn't soot all over the engine), but it is clear exhaust gases have been leaking.
One seemed to slide forward (a lot... weird), so it is perhaps blocking the manifold passageway as well - the leak and blockage would reduce the power in the flow available to drive the turbo, and explain a lack of sufficient air to burn all the fuel. I'm just thinking it may have been this way for 1.5+ years!!!
2 gaskets @ $6.xx each... I'll install them on the weekend then see.
If they black smoke a bit anyway, what can be done to diminish this/eliminate it (a little more boost?)
Old 03-21-2007 | 08:36 PM
Box5's Avatar
my truck has no smoke, theres a smoke screw on the back of the AFC u can adjust, and also the starwheel that can affect fuel/smoke.
Old 03-22-2007 | 07:13 PM
kevellis32's Avatar
No smoke means no fun
Old 03-22-2007 | 07:16 PM
Box5's Avatar
well, once I get this 5spd trans in, alittle smoke will be in my future.
Old 03-22-2007 | 07:19 PM
TxDiesel007's Avatar
As ive said before
thats how it starts... U may as well swap in a 215 pump and have some real fun too...
Rick
Old 03-22-2007 | 08:24 PM
Box5's Avatar
I'll have to hold myself back, because once that first mod gets done, it's all over lol. Especially when theres people like Rick with 1000+tq hanging around here, lol.
Old 03-25-2007 | 03:36 PM
ScottN's Avatar
I got the failed gaskets replaced...
A BIG improvement on the smoke side (feels like better performance too, but that may just be my "know-o-meter" letting me know that if the fuel is being more fully burnt, it has to be putting down more power.
There is still a dusting of smoke as it accelerates at WOT 3rd gear to redline. Probably fine, I'll make up my mind when I can have a chance to let the turbo catch up (pull a big trailer).
For now, she's all good.
Edit: Oh, and I didn't bend either of them after taking them off... I know, shame on me for not noticing it for so long.
Old 03-26-2007 | 09:31 AM
Lil Dog's Avatar
Wow, the right gasket is totally distorted.. That may help out a tad on exhaust flow.
cruiserdar
08-26-2008 11:31 AM
cruiserdar
08-25-2008 09:22 PM
Dodgezilla
03-08-2006 08:59 AM
pjram2002
07-08-2003 03:55 PM
tobyw
12-11-2002 11:54 AM
Quick Reply: How much smoke is normal?
