How much boost should a stock turbo make
Old 11-10-2007, 07:12 AM
heykw's Avatar
On my 98 12/v I slid the fuel plate and cut and plugged the line going to the waste gate how much boost should I be making it will only hit 24 psi. and 2500 rpm I know I need a spring kit and I am considering a 4000 GSK will the spring help the stock turbo build more boost?
Old 11-10-2007, 04:25 PM
97 D-Tec's Avatar
u should have just bought the lil L fiting that has a allen head screw in it so u can adjust the boost... my trucks got a stock turbo n it makes 30 psi untill it hits top gear n then it makes 40 psi.. if u get a 4000 rpm springs some places where u by them from also recommend makin sure u have enough fuel to get to that rpm and some different valve springs
Old 11-10-2007, 04:50 PM
97' CTD's Avatar
Anything over 35 is HOT air.
Brandon
Old 11-10-2007, 06:57 PM
Willy91's Avatar
well I can push 53 psi out of my stock charger right now. But You're best to keep it around 35 or so for efficency reason.
Old 11-10-2007, 09:06 PM
heykw's Avatar
So How much boost should it make as set up? Do I have a boost leak? I would think it would make close to what my 01 does 36 psi w/ welded waste gate. with the line cut the waste gate should not open right?
Old 11-10-2007, 09:31 PM
1stGen545's Avatar
This is 3 runs at 4K at over 40psi about 5 hours ago. 35 is max on a stock 35. it will go higher but its useless I just didnt have it set yet.
Old 11-10-2007, 11:19 PM
thewished's Avatar
ouch... I have been told by a few shops that 35-40 depending on how you drive it..
Old 11-11-2007, 02:26 PM
1stGen545's Avatar
thats 35psi for about a year and 40-45psi for 3 10second runs. I just made a HX35/40-14cmWG hybrid and will set to 40psi Max. The 35 and 40 use the same shaft but the 40 has a little larger exhaust wheel.
Old 11-11-2007, 06:10 PM
heykw's Avatar
Ok thank for the info so if my truck is making 24 psi something is wrong?(Boost leak)
Old 11-11-2007, 06:56 PM
thoscos's Avatar
heykw,
My truck when stock only made about 25 lbs boost. With my current setup I can get in the upper 40's if I set it that high. I have it set at 38.
More fuel = more boost. A gks will not effect it very much.
Old 11-11-2007, 09:32 PM
deereguy07's Avatar
With a fixed elbow out of a edge juice box put on my 96 I could hit 47lbs when it shifted to overdrive and lock up. I've pulled the auto out and don't know what its going to be with a manual.
Old 11-12-2007, 06:03 AM
97' CTD's Avatar
I say you are good.
Brandon
Old 11-12-2007, 06:56 AM
heykw's Avatar
thanks for the help guys I will add more fuel and see what happens
Old 11-12-2007, 08:56 AM
thoscos's Avatar
heykw,
Another no cost way to get the fuel to come on quicker in the throttle range is to loosen your afc spring full loose and push the afc housing full forward. Depending how far you want to dig into the afc you can swap the big washers (that hold the rubber bellows). The lip on the forward washer restricts how far the afc can move forward.
have fun,
Old 11-13-2007, 02:56 PM
12valvetom's Avatar
I ran 44psi and it whisled like a super charger and it got hotter then all hell... it burried my pyro. and kept going
Quick Reply: How much boost should a stock turbo make
