How many quarts, and what type of fluid for my Dana 80 LSD?
I'm changing the fluid tomorrow, what type of fluid do I need and how much of it?
Thanks!
Thanks!
http://www.dodgeram.org/tech/specs/a...RBI_specs.html
Lube grade & brand is wide open. You'll need something with friction modifier to quiet your limited slip.
Unless you are towing really heavy in hot weather, I would suggest a synthetic 75w90 oil. If you are going to be towing heavy and don't see really cold weather, you could look at 75w140. As far as brand goes, that is your choice.
80w90 didn't cut it for my LSD; didn't matter that I put the friction modifier in it, it still chattered real bad. It was recommended to me a long time ago to use 80w140 so that's what I've used ever since..... still use friction modifier with it.
I just did the fluid replacement on a 98, Dana 80 LS with Mobil One 75W-90. Ten pints is the correct amount but don't believe Mobil that you don't need a friction modifier, my truck chattered terribly in turns. I siphoned out 10 oz of gear lube and replaced it with 10 oz of Mopar friction modifier, the chattering went away immediately.
Recommended method is to add about 4 ounces at a time. Drive the truck including lots of figure 8s to allow the modifier time to get into the clutch material. If the LSD chatters add more and repeat.
I do know you want to use at least the correct amount of FM, because in my 99 with the D80 it didnt work as well without it. I to used 75/140 from O'Riellys. My 04.5 doesnt require the FM as it is a mech. posi and works so much better than my 99's.
Yep, just about any parts house will have the friction modifier. Just tell 'em you're looking for the LSD friction modifier. It's been a while since I did mine, the modifier may not be specifically state it's for LSD's, but should at least include them so don't let that hinder you.
mcolectd
07-08-2009 10:43 PM
04ctd
08-04-2008 11:41 PM
jwb600
13
06-17-2008 08:35 PM
