How many miles are you getting on your Automatic??
Old 10-19-2006 | 08:12 PM
  #31
TEXWS6's Avatar
dumb question......how and when should i lock out OD??
Old 10-19-2006 | 10:32 PM
  #32
kelownadiesel's Avatar
Mine was done at 155000 by previous owner.He put in upgraded tc.Been going strong,trucks at 270000 now.Blew the cooling lines twice and tranny is still smoothe.they say that the stock tc is the culprit (obviously)
Old 02-01-2007 | 02:22 PM
  #33
utah9412valve's Avatar
tranny
well i got a 94 12valve with 175,527 right now i even have pump up and straight piped
Old 02-01-2007 | 03:11 PM
  #34
GearHd6's Avatar
I've got a 96 Ram with 177k on the stock tranny.
Old 02-01-2007 | 06:31 PM
  #35
steveh1155's Avatar
257,000 on mine - all stock. Only problems I ever had were cooling line leaks and dipstick seal leak. Shifts fine - TC locks up okay most of the time.
Old 02-01-2007 | 06:51 PM
  #36
TIMMY22's Avatar
149K on mine, not to happy on towing heavy loads from a dead stop at the bottom of a long grade. guess it's just me, no lockup in 2nd so I can't get it above 30mph until i crest the hill.
Old 02-02-2007 | 04:23 AM
  #37
kd460's Avatar
155,000 and the converter is just now starting to shudder. Hava a #10 plate just behind stock location, afc cover slid forward a little, starwheel adjusted, 3k gov. springs, tow 7000lbs about 8-10 times a year. I would completely flush trans every spring with new fluid. About 55,000 miles with the above mods listed. New HTS trans going in next weekend. KD
Old 02-09-2007 | 02:10 AM
  #38
rockrunner's Avatar
i have 267000 on mine right now the TC is slipping badly but the tranny still shifts pretty well except for when its cold, just ordered of for a performance tranny and TC today hopefully that will make a world of difference
Old 02-09-2007 | 06:34 AM
  #39
fortunate1's Avatar
Mine worked great for around 200K, then I went for a complete DTT "master upgrade" (new/more clutches, seals, tc, vb, etc.) installed by Chip's Trans. in TN. I knew that I'd want to do this eventually to withstand the bombs, so the upgrade was done without having to endure a catastrophe and clean out a bunch of junk. Also, the 95's have an aluminum planetary carrier. 96 and later updated this piece to steel; that's also part of the trans upgrades for 95's (and probably 94's too). This was much cheaper than a full trans swap, and the results are the same. Bottom line on ALL trannies: keep the fluid clean, keep the fluid cool.
Old 02-09-2007 | 07:58 AM
  #40
Adam3291's Avatar
I got a buddy that has kept his truck stock and he has 230,000 out of his auto tranny. Only thing that has been adjusted in the bands once. I doubt it will last to much longer cause a set of 370's is is going in.
Old 02-09-2007 | 08:11 AM
  #41
jonesracing's Avatar
187k and going strong all stock up to 178k then added a good converter and shift kit. with motor mods. #1 thing do not over heat your automatic. when my transmission was stock I had to baby it. I am sure you can kill an auto very quickly if you dont drive it right.
Old 02-09-2007 | 11:13 PM
  #42
Mslaughter's Avatar
Mine has 95k on it, the trans is ok (not bad, not great) but the TC slips terribly. Since I have to pull the tranny to replace the TC I figured I might as well put in a new tranny while I'm at it.
Old 02-10-2007 | 05:55 AM
  #43
odin1954's Avatar
I had my 96 2500 4x4 5" exhaust S&B cold air intake bigger injectors ,trans up grade at 115,000 it was still workin good but needed a rebuild
Old 02-10-2007 | 09:30 AM
  #44
Dinner's Avatar
We have 168+ miles right now on our auto. Still shifting good, smooth, etc. Used to pull a 24ft stock trailer too for a few years. So it's probably a matter of time before it goes
Metal Twister
11-03-2012 10:55 AM
tool
24
01-16-2009 02:53 PM
Jimminyc
25
10-02-2007 08:41 AM
Txwelder
09-27-2007 07:48 PM
joelmopar12
01-23-2006 11:00 AM
Quick Reply: How many miles are you getting on your Automatic??
