How long are Larry B's HD starter contacts supposed to last
Old 12-03-2008 | 05:53 PM
megajoltman's Avatar
Question How long are Larry B's HD starter contacts supposed to last
While I was in the ER for ten days I had my GF try starting the truck to run it for awhile. She said the starter just clicks or there is no noise at all. I finnaly got home and tapped the starter with a hammer and it started right up.
I installed Larry B's Super Size solenoid contacts and plunger about 2 years ago so is this how long they last for
Check and cleaned battery terminals etc every thing seems okay?
Old 12-03-2008 | 07:03 PM
infidel's Avatar
It all depends on how often you start the truck.
I've had Larry's contacts for about 175k (8 years) on both trucks. Stockers were replaced at about 60k before they failed but it didn't look like one side on both starters had long to go.
Larry has this set up that may solve your problem or you could build it yourself http://startercontacts.com/relay.htm
Also check that the problem isn't your tranny starter safety switch.
My shifter got out of adjustment and I had to pull down into drive then slam it back up into park to get it to crank until I fixed it.
Clicking noise during this period was the shutdown solenoid.
Old 12-03-2008 | 11:03 PM
Thanks for the link and tips
buckman361
11-13-2008 09:54 AM
apache
02-06-2005 10:25 PM
redramnc
08-03-2003 12:03 AM
doodah
06-03-2003 12:16 PM
MJR
03-16-2003 08:26 PM
Quick Reply: How long are Larry B's HD starter contacts supposed to last
