Hot Tranny
Old 12-19-2007 | 01:08 PM
xyz12383318's Avatar
Hot Tranny
In my Suburban I am running a 92 Intercooled Cummins and a Tranny I pulled from an 01 and swapped valve bodies and overdrive shafts to turn my 47RE to an RH. Anyway, I was towing some 4 wheeler in the mountains yesterday at low speeds and my tranny tempos just kept climbing and climbing. I pulled over and melted snow on the cooler when it got to 280 degrees. It is not exchanging heat with collant and usually runs super cold. I am embarresed that my tranny would get that hot pulling a couple of 4 wheelers in the mountains slowly in the snow. How should I fix this problem?
Old 12-19-2007 | 05:04 PM
Ronco95's Avatar
If your torque convertor is not locking up, you will make heat. Do you remember that last "shift"? My truck will cool the trans fluid 15* almost instantly when the convertor locks.
Ronnie
whosdunit
02-16-2019 04:07 PM
6.7 4ever
11-07-2011 09:07 PM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: Hot Tranny
