Holes in intake manifold, should they be plugged?
Old 09-21-2005 | 06:46 AM
Iron City's Avatar
when I was installing my boost guage, I noticed a couple of holes on the intake manifold that were not plugged. I bought the truck a few months ago, so I'm still learning about things the PO did, or didn't do. Just wanted to run the pics by the list to see if this is normal. I circled the holes in red.
BTW, here's where I fitted the boost plug on the intake.
EDIT: sorry, just realized I posted this to the wrong forum, should be in "12 Valve Engine and Drivetrain"
Old 09-21-2005 | 08:32 AM
J BODY's Avatar
The only one I would be suspicious about is the second picture. Most of the intake bolts are drilled straight into the intake. If that hole doesn't "dead bottom" I may be putting a bolt in it. I'm sure a more knowledgeable 12 valve guy will chime in here.
Old 09-21-2005 | 08:38 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Those "holes" don't look like a problem to me. I can't see into them very well but they just appear to be unused mounting spaces for that engine when used in a different vehicle.
The boost gauge is mounted properly as well Now get out there and enjoy that 12 valve, as it is a REAL diesel
1969mach1
04-05-2007 07:47 PM
BA05'CTD
01-07-2007 03:08 PM
trik396
12-01-2005 09:21 AM
Bobcat698
09-24-2005 10:51 AM
Quick Reply: Holes in intake manifold, should they be plugged?
