Higher Warm-up Idle
Old 04-09-2007 | 12:52 AM
kevellis32's Avatar
Higher Warm-up Idle
Its just become really cold here in colorado and when leaving my friends house who has an 04.5 he has the ability to raise his idle through his his cruise control buttons. Is there any program that I can put on my truck to do the same?
Old 04-09-2007 | 08:04 AM
TIMMY22's Avatar
not going to work on a mechanical linkage injection pump. your buddies is electronic.
Old 04-09-2007 | 09:02 AM
Andy505's Avatar
I find an ice scraper stuck between the seat and throttle works wonders
Old 04-09-2007 | 09:17 AM
cheapskate's Avatar
my ice-fishing scoop works great for me
Old 04-09-2007 | 01:32 PM
Muddin_dude06's Avatar
I have a piece of solid steel 1"x2" and 16" long that I just set on the pedal and I can bring the RPM's up to 900, anymore than that and it will go straight to 2500rpms.
Old 04-09-2007 | 08:48 PM
Fueling around's Avatar
I keep a scrap 1x2 in the cab.
Old 04-09-2007 | 08:50 PM
Reset the tension on your GSK. You should be able to set it at any rpm.
Old 04-09-2007 | 09:19 PM
cumminsdriver635's Avatar
You can mount an electric solenoid on the injection pump if you make a bracket, and figure it out. It can be done. Someone had pictures they posted one time. Just depends on if you want to do the work to install it or not.
Eric
Old 04-10-2007 | 12:35 PM
Lil Dog's Avatar
I had a solenoid installed for a while, the darn vibrations from the engine just eats the inside of that thing out no matter what I did to the wires with epoxy, tape, liquid tape etc etc. A few months and it would short out or have a break in the coil. Worked great when I had it, now I just have some instrument tubing bent to fit between the center seat and pedal. Contemplating a cable install instead.
mtb1982
55
01-20-2020 11:45 AM
klx650a2
07-22-2008 07:47 PM
herb
07-18-2008 09:25 AM
jj3500
12-26-2005 12:02 AM
jerry007
10-28-2004 09:24 AM
