help with tc lock up switch
okay so i did the relay wire up so the tc would free if i hit the brake, but with the switch on or off or centered it locks my truck in 2nd or 3rd and wont use the tc. i had to pull the wire going to pin 11 and disconnect it and restart my truck to get all gears back and tc. i did notice in the write up relay pins 86 and 85 are in a dif place. starting with pin 87 and going right is as follows on the relay 87,87a,85,30,86. now the write up shows 87,87a,86,30,85. has anyone had this problem?
The reflash just changes the programing for the pcm as it relates to the tranny. From what I understand the only thing you will notice different is that a lockup switch will work.
sallyman1
03-03-2008 08:37 PM
RAM123
04-10-2007 08:18 AM
mr T
21
06-01-2005 08:48 AM
