Help!! New tranny leaking
Old 06-30-2016 | 07:38 PM
flyingd's Avatar
I just put in a rebuilt tranny. I was putting in the tranny fluid and it started leaking. I looked under the truck to find out where it was leaking and it looked like it was from inside the bell housing. Is there a vent I don't know about? Do I have a bad seal? I made sure that I didn't move or remove the tc as I was putting the tranny in. I am at a lose.
Help
Old 06-30-2016 | 07:56 PM
gorms's Avatar
Was the truck running or off? If running I would suspect the input seal was damaged, could always be the pump seal between I guess?
I want to say you don't put all the fluid in with the truck off, maybe it was overfilling somehow....need the pump turning to get flow to the converter.
Old 06-30-2016 | 09:45 PM
flyingd's Avatar
Thanks ... I think that was it
Old 07-01-2016 | 12:00 AM
Robert Rausch's Avatar
Mine takes 3.5 gallons and it will overflow if I try to put all of it in without starting the engine. I put in about 2.8 gallons and start it and then pour the rest in.
lilsuzuki4x4
09-01-2011 01:50 AM
Brian.B
01-31-2011 06:04 PM
Black Dog
12-03-2009 08:18 PM
Common
06-09-2008 12:16 PM
turbo6justin
18
09-12-2006 11:06 AM
Quick Reply: Help!! New tranny leaking
